ASrock H170 Fatality, Power LED
Scary_crow
25
Hi, sorry in advance for asking a noob questions, but this is my first built and I think it is safer to check before I make a stupid mistake an burn my new PC lol
For the power LED, my case (IN Win 503) got both the 3 pin connector and the 2 pin connector (the 2 pin are connected to the 3 pin connector, and then the 3 pin connector go to the front panel). My motherboard is ASRock H170 Fatality, and in the manual it got Power LED shown in both PANEL1 and SPK_PLED1. Am I supposed to connect both? If I only need to connect 1 of the 2, should I connect the 2 pin to PANEL1 or 3 pin to SPK_PLED1???
Also, for the motherboard speaker, is there +ve and –ve?? Or it can be plug in either way???
You won't burn you PC just like that. You only need to connect one so my guess is the one which is connected to the front panel. 3-pin to SPK_PLED1 looks like it.
