[SOLVED] Asrock h87m pro4 startup issues
luuk.bergsma
Commendable
Jun 30, 2018
26
When I try to start up my pc it doesn't show anything on screen. I connected a speaker and heard 3 short beeps, I searched it up and all I could find was memory problems. Although I've tried to swap my ram out it still doesn't work. Can someone please help?
Specs
I7 4790
16gb ddr 4x4 sticks
GTX 1070 gaming x
ASRock h87m pro4
4 beeps is a system timer failure. So your ram may work in one slot, and try and reseat your cpu and check for any bent pins,if not your board is dead.
Reset BIOS...? Double check all cable connections and AUX power ports?
Start with minimal boot.
CPU, 1 stick of RAM (make sure you put it in the correct slot/check manual), keyboard, monitor (plugged into MB port). See if you can get into BIOS. If you can, repeat process, adding one component at a time.
Does it work without the GPU?
I have the same motherboard and I've tried with a GTX 2080 and had the same problem.
With my Sapphire R9 280x and it beeps sometimes, but it initializes sometimes too.
