Question Asrock polychrome help
gg83
820
400
19,260
Is there a resource for learning to program your own rgb patterns on the case fans? Polychrome has one rainbow preset but I would like a static rainbow pattern and not cycle through. Thanks for your time
Try to set the effect to static, and in the polychrome software try to see if you're able to set each individual LED to a different color. This works for the motherboard lights of my x570 taichi, I can get a static RGB. But I don't know if your fans are software friendly with polychrome. While RGB technology have come a long way, the software sure hasn't.
