ASRock RMA process, need some help
Basho
17
I have an ASRock z77 pro3 that, after many months of use, has had a System Timer Failure (with testing, has proven to be something wrong with the motherboard, every other component worked great).
I considered the RMA process and have found that they may charge me a fee of $50 for a fix or replacement. If that's the case I may just buy another brand of mobo with the money that has a better customer support.
If I should continue with the RMA process, I still do not know what the form means by 'VGA' (Video Graphics Array [a form of video transfer right?]) when asks me to list my other computer parts. The options after the fill in space are: Onboard, AGP, & PCIE. It requires me to put something and I'm not sure what; my motherboard? my graphics card?
So, I should fill out that part with the name of my motherboard or my graphics card? I don't see why they need to know this, since I tested the motherboard without the graphics card as a precaution
It has a fill in section, which is required, and a drop down bar next to it which only allows one selection.
Basically:
VGA*
[_____________] [Please select ↨]
Okay so, if I were using a card, input that. and if i was not, what would I put?
And if I was running a card, why label that part 'VGA'? I thought that was an older method of video transfer
