ASRock Z270 Extreme4 Kaby Lake ATX Motherboard Review
OK, OK, but the supply voltage is supposed to be an average (my word constant was relative, meaning the average typically moves a few millivolts rather than tens of millivolts), and my meter measures averages. I'm sure I could get more data by measuring peaks and valleys, but I'm only even attempting to measure inconsistent motherboards in a consistent way.
Right. Which is why you aren't able to form a true conclusion on what is happening...
Except that I can see the change in what's happening to the average. Yes, I have noticed that VDD looks like a furry line on an oscilloscope until you zoom in, but when they say 1.35V, I don't think their talking about the peaks or the valleys, is it fair by you if I say "nominal" instead?
Not really, no. It's more fair if you explain why you think it is overvoltage.
The "furry line" would tell you why the nominal voltage is set that way and whether it's done for good reason or not. This is why your info is half baked.
OK, so what would you prefer I use instead of the nominal voltage? So far I've only said that the average is higher on some boards, and you're telling me that average isn't good enough even though I'm fairly certain that it's going to be what nominal voltage looks like when it reaches the DIMM. By that metric, you also wouldn't be satisfied if I used the manufacturer's voltage check points and only on boards that have them.
Thomas, I think he's being critical that you aren't measuring deviations; you may have an "average," but what if it's the peaks or valleys that are actually mattering most?
Scone, I think Thomas' point, and one his methods consistently demonstrate, is that his measurement results accurately predict the behavior of the products being tested. This suggests that even if the peaks/valleys are mattering, they are either the same on all boards, or correlate at a statistically significant level with the way he is measuring.
I believe there might be a way to test this, Thomas, if you can get your hands on boards with different numbers of power phases for the RAM. Use an oscilloscope to see if the waveforms are notably different based on number of phases, and also correlate with the results you get.
Well, you would need to measure them all properly and work it out...:)
This wouldn't give you anything conclusive, either. It depends on more than just phase count.
Hmmm, then I'm going to say it looks like you are asking for what amounts to many more "significant digits" than are needed to get a practical, relevant answer. Thomas' methods may not be as precise as a disciplined EE may like, but they serve their intended purpose, including they are not likely to lead someone to pair the "wrong" components and then wonder why they don't work.
No, not at all. Without using the right methods, you're making blanket statements. That's the issue here...
And the funny thing is, it was Thomas who was mistaken into thinking I was referring to the CPU socket. Let alone the readers making mistakes...
While that could add more to the discussion of why one board overclocks better than the other at the same average voltage (more noise, poorer signal quality), my major point was to make sure everyone was getting the same opportunity in the O/C test. That's opportunity-driven, not outcome-driven. I'd hate to see a company win the O/C test by using unsafe voltage levels, which would of course be an extreme example of what I'm trying to avoid.
Considering that this is the same board with an extra controller or two left off? Flip a coin.
