Hi guys,
This desktop I'm running now was my first build ever, and I did it about 2 years ago. It's an i3770k with 32gb RAM, an Asrock z77 Extreme 4 mobo, corsair hx750 pro psu. It's been running perfectly fine since I built it. I put it into an older HP ATX case that I already had, basically gutted it and put all the new stuff in.
Anyway, Asrock comes with this software called AsRock Tuner. It basically lets you tweak settings within windows. I had my Core i7 moderately overclocked (to 4000 from 3500).
The concern I have is that the fan doesn't automatically adjust based on CPU thresholds. I have four fans in the case, and I am using the stock ones it came with:
That screenshot shows the utility screen. Basically, I have CPU FAN1 connected and CHASSIS FAN 3 connected. The other two are non-existant. I noticed I can't automatically have CHASSIS FAN 3 ramp up / down in relation to temperature, and I can't connect it to CHASSIS FAN 1 because that is a 4-pin connector and the fan only has 3.
So, I have a few questions here, because the other day I was transcoding videos out of lightroom and I came back in my office and could smell just a very faint burning type of smell. I looked at the tuner utility and my CPU was at 110 degrees celcius (!!!!) and the chassis fan 3 was just putzing along at level 3 or something.
? How do I get the fan to ramp up automatically when the CPU goes up? Do I need a new fan with a 4-pin connector?
? Why did my CPU get so hot? I have thermal protection enabled in the bios. Shouldn't that have shut off the CPU automatically when it reached a critical threshold?
should i add more fans or get a better case? I like to keep the fans pretty quiet unlless I'm doing a CPU intensive task like transcoding videos or photos or something.
Thanks in advance!
1 built into the PSU, run by the PSU
1 at the top of the case (inlet air, I think). This is connected directly to a 3-pin molex from the PSU
1 at the back of the case (exhaust, I believe). This is connected to the mobo with 3-pins
1 on the CPU itself. This is the one that came with the i7-3770k.
Thanks in advance!
