Asrock Z77 Extreme4 with OC I5 2500K & 2400mhz memory. Will it work?
Ferio121
20
Hello everyone,
I'm unable to find a clear answer regarding what I've read on several forums.
I want to buy 16gb of memory for music production and I can get the F3-2400C10D-8GTX for 50 euro's, so that's a pretty good deal for one of the best sticks out there.
This memory is 2400mhz and I read that for me to run at 2400mhz I have to go in the bios of extreme4 I set the voltage manually higher to run on 2400mhz, so ok that's is not a problem.
However, I read several messages that the I5 2500K won't run higher than 1866mhz, so anything above this is pointless, but I see other people also disagree with this.
So, my question is if this memory will work at 2400mhz with my setup or I cannot use the full potentional of the memory and better go with 16gb of 1600mhz/1866mhz with low timings?
Thanks in advance!
That CPU has a maximum memory multiplier for 2133. With some CPU BLK overclocking you may achieve ~DDR3-2200, but not 2400.
This is what you want to maximize performance:
F3-2133C9D-16GTX
