ASRock z87 extreme4 vs pro4
Starkiller1
22
Hi guys,
I am building a new pc and i just wanted to ask what the difference is between the mitherboards ASRock z87 Extreme 4 and pro 4. I am not planning to overclock anything, so are there any other major pros to the extreme version i should be aware of and do they justify the price difference?
Thanks in advance.
The extreme supports both nvidia and AMD dual GPU card setups and the power phases on it are better. If you are not planning to OC then you can save even more money and go with a board with H87 or B85 chipset and of course you will not need a "K" CPU.
Thank you.
If you could explain what is different about those power phrases and suggest a cheaper motherboard i would be grateful. I am getting a intel core i7 4770 and gtx 760.
