Assassin's Creed 3 Low FPS/Stuttering
P Lash
Hello,
I just started playing Assassin's Creed 3 and I'm getting pretty bad performance and low FPS (15-20) in Boston, to the point where playing through Boston has become quite painful. 🙁 Other areas of the game, however, like the Frontier and the Homestead, are working quite fine. I change the settings, lower the resolution, no difference at all. Even tried getting the latest ATI drivers 12.11 beta, no difference.
I googled this issue, seems like its pretty common, but I can't find a solution for it.
I don't get why, because all the previous AC's have ran perfectly on the highest settings, plus other games like Crysis, GTA 4, Far Cry 3, Sleeping Dogs etc are running quite well with no issues on my rig.
Config is-
ATI Radeon 6770 2 GB GDDR5
3 GB RAM
3.2 Ghz Core 2 Duo
Windows 7
Please help.
i have a shitty laptop
A-4
HD 6670 2 GB
Ram 4 Giga
and i play AC3 well..it's playable
It's 2014 and the problem was never fixed. i7-2600K, GTX 690, latest WHQL drivers, same stuttering when panning the camera around the Boston skyline, but face away toward the docks and it's perfectly smooth. CPU and GPU usage are low.
Old thread, but I actually was able to play the game properly after I installed a beta driver for my GTS450. I believe it was the 365.?? beta drivers. Worked like a charm and could play it with good FPS even in Boston level.
I think my settings were mixed. Some low, some medium and some high.
i find it dude now u can play Method 1.
1. Open cmd.exe as administrator
2. Type bcdedit /set increaseuserva 2500
3. Restart PC
4. Run PC
5. Play Assassin's creed 3 with no lag :)
Method 2.
1. Download 3D Analyze from here: http://www.mediafire.com/?2na38bmqayq...
and razer game booster from here: http://www.iobit.com/gamebooster.php
2. Run 3D Analyze as administrator.
3. Press "select", then go to folder where you installed AC3, press AC3SP.exe the open.
4. When selected AC3 press performance mode which is at the bottom.
5. Press "run", when playing run razer game booster and press ctrl+alt+b
6. Enjoy AC3 with no lag.
ah yeah for those links dont try them just go google and rech Razor GB and 3d annalizer u will find them easly ^^
A driver update and some messing around with the GPU control panel worked for me.
BTW, this thread has gone long enough. It's nearly been 2 years since this thread was posted.
