Assassin's Creed Syndicate low cpu usage
Shalom1
32
I recently bought Assassin creed syndicate and played it.The first two missions run smooth as butter but after that in sequence 3,its lagging so much.I dont understand it.I checked in the task manager and the cpu usage was between 13-50 and sometimes it goes to 70-100 ingame.Please help.
Specs
i5 4210u 1.7-2.7ghz
Nvidia geforce 840m 4gb
4gb ram
Maybe it is the heat. The first 2 missions are probably not that intense in terms of action so it probably could handle it. After that, it picked up so the laptop needed more ram and the cooling was not enough. You could buy more ram and a laptop cooler to solve these problems.
But when the cpu usage is above 50%,the game runs smooth.
And for some reason the cpu usage goes to 13%-28%
Heat is not the problem as the laptop is cool as i keep it in my lap and play
I think the cpu is not being used fully
I need a app so that my cpu usage is above 50%
And Sequence 3 is very very very much laggy
Other people have this problem but their games are pirated
In rest all games ,the cpu usage is high and the games dont lag a bit
My father would not allow me to insert more ram as the laptop is his
This problem is only in this game only
HELP
Assassin's Creed Syndicate is a very poorly optimized game. It's beautiful but optimized badly, even with high end hardware. I'm sure more RAM will help somewhat, but I strongly recommend that you watch this performance review ASAP before you invest in upgrading anything. FYI: I own this game on PC.
Assassin's Creed Syndicate PC Performance Review
! Skip to time index 6:40
https://www.youtube.com/watch?v=1d0rsT0hauo
velo3100: I can assure you that the game is not corrupt as I installed it from a cd and it took me 2 and a half hours and i dont have that much time to install it again.
rcald2000: How is this game running for you ? By the way ,You have got an awesome rig
turkey3_scratch: I have no idea about how to check gpu usage.Could you suggest some software for it ? and how to check the usage of each core ? I just looked at task manager and it only shows me total cpu usage.Do you own the game ?
I am a great fan of the Assassin's Creed series and ran all of its games on high-ultra settings except unity. I ran unity in low-medium settings and it ran without no lags,glitches and bugs.I ran it on 1366x768 and it felt great. It just took a long time to load (about 3-4 minutes). Now i am running syndicate at 1280x768 and its lagging still.
I heard that pc's which could run unity would be able to run syndicate as well as they use the same engine.I know my pc is not that great but come on. I ran unity smoothly!!
I dont want this game to go to a waste.
Another question
Does the latest update from ubisoft (I think it is 1.21) helping ?
http://imgur.com/R2LRApf
http://imgur.com/B1fyIdN
Hey Shalom. Thanks for the compliment, I appreciate it. I thought you'd appreciate the screen shot that I took in your honor. My display has a resolution of 3440 x 1440, so this is how Syndicate looks to me. I also had a screen shot of GTA5 that I took over last weekend, so I included it as well. Because of your post, I JUST updated Syndicate now. Unfortunately I don't have it on Steam. I got the game for free with my new Samsung 950 Pro SSD. It's crappie that it was Ubisoft's Uplay code and not Steam, but I can't complain too much since it was free.
The game looks just beautiful, but I will say that when I attempted to play it on one 980 Ti, I experienced input lag, which I find annoying. I noticed the lag from the day that I installed it, about 7-10 days ago. I had one of my GPU's out because my Intel 750 takes up one of my 3 PCIe3 x16 slots, and the Samsung 950 Pro uses a M.2 slot, which when occupied, disables one of my other PCIe3 x16 slots. So now I have to decide if I'm keeping both SSDs, which would require a motherboard upgrade, or sell one of the SSDs. I'm obviously not going to return a GPU. Like I was saying, I think this is a beautiful game, and it appears to be stable so far, but not optimized. Normally I don't have to be too concerned about performance, or lack of, on my setup, but with Syndicate I do. I know that 3440 x 1440 is a reasonably high resolution, but I never experienced noticeable input lag on any of my other 30 titles. But it's typical Ubisoft in my opinion. This is not saying anything bad at the Assassin's Creed series, but Ubisoft in particular, will always release this series year-after-year, no matter what the quality level is. Unity was clear and irrefutable proof of that.
Shalom, please don't forget to watch that performance review. It's by Joker Productions; he's a guy that I mod for and he has amazing unbiased reviews. By the way, the fact that Syndicate lists a 6 GB minimum and a 8 GB recommended, tells me that you should eventually get this laptop upgraded to that level, if it can be upgraded. I don't know what mfg or model of laptop it is, but I find that many laptops with ultra low voltage processors have memory soldered onto the motherboard and can't be upgraded. Hopefully in this case, I'm wrong. By the way, this game does take a while to load for me too, although not THAT long. You could always upgrade to a Samsung 850 EVO SSD to remedy that.
In reference to your question about GPU / CPU usage & temps, you could download HWMonitor. Everyone has their favorite tools: HWMonitor, or MSI afterburner, or EVGA Precision, etc.
By the way, you have a much MUCH better laptop than mine. My laptop is a Lenovo X230, which is a business laptop. It relies on HD4000 integrated Intel graphics, and until just this year was my primary computer hooked up to two 1920 x 1200 Dell Ultrasharp monitors. At the time, I would have killed to have your laptop, as mine could only play games with rudimentary graphics. Then at the beginning of this year, I built my PC. One of the things that I really respect about Rockstar is that they made the PC port of GTA5 work with just about any hardware there is. I've met people online who have computers that are so incredibly old and still play GTA. It's good business because it means they can sell the title to practically anyone that has a functioning PC.
One other random thought: I saw your comment about installing this game off DVD. It's funny because my first game for the PC this year was Witcher 3. I bought the game on disc because I was being very ol' school and had never used Steam. Then when I initially got my GTX 970, it came with a free Steam code for Batman Arkham Knight. Horrible game, but when I saw the convenience of Steam installations, I never looked back.
rcald2000 : Thanks for the screenshots.It's incredible that you are running it on 3440 x 1440. I will check HWMoniter tomorrow.
I also own GTA 5. I might disagree with you on the fact that GTA 5 is pc optimised and old pc's can run it. In the beginning,even i thought that
But later, I changed my mind. I think the original game was great and the updates ruined it. The day one patch worked wonders for me but subsequent patches made gaming horrible for me. Now 5 minutes of great gameplay and the rest minutes of horrible gameplay. In one patch, buildings, roads, people and basically everything except me kept vanishing for some reason. I never found out that reason.
Syndicate and GTA 5 looks great for you. Syndicate more or less looks the same for me.Not sure about GTA 5 as I have not played it for 2-3 months.
You are wrong in my case. My ram can be upgraded to a max of 8gb ram. Will ask my dad about it but I know what his answer would be."Concentrate in your studies". Same old parent's dialog.
I over clocked my gpu to 135 MHz. Could this be a problem ? I overclocked it to play Far Cry 4 on high and to play Just Cause 2 on high-ultra setting and to play a number of other games. These games ran great. The games are pirated by the way.
I would never ever use steam again as it stole my money and my game. A few years back, I wanted to play The Amazing Spider-Man
(horrible game but I like Spider-Man) on pc. Sadly, this game was not available on disc in India. So I went on a search to find this game. First thought about emulators but could not find one working. Then I found Steam. Bought it for Rs 2500 and played it. After a month or so, the game stopped working. Steam told me that I had not installed the game. Tried to reinstall but then it gave me my biggest shock.
I TOLD ME THAT I HAD NOT BOUGHT THE GAME. Furiously, I wrote a ticket to Steam. After 3 days ,the ticket vanished into thin air. And then in my anger I pirated it. Now i love it (the Game ,not Steam).Steam also has very high prices though.
By the way, I told the loading time of Unity and not Syndicate. According to me, Unity was way more optimized for pc than Syndicate. And i just noticed that now Syndicate is not loading into Sequence 3. Twice It loaded and horrible lag. First i thought that it was because of one video which it didn't show me so I deleted my save-game and restarted the game. Now its not even loading. It loads the game normally, am able to go to the white room (loading room) and it loads for a minute a so and then hangs up. I have to force shut-down my computer. Will check it tomorrow though. Sequence 1 and 2 loaded fine .Other people also have a similar problem but in their case ,the game crashes.
Help is required to reduce lag in Syndicate
Just checked HWMonitor with Syndicate. I had a very unusual result. CPU Core 2 was found to be very hardworking and Core 4 was the laziest. Core 3 and 1 were average performers. After launching the game ,everything's fine and running great. Then the performance dips in the white loading room and further in the black screen. Game justs hangs up. The black screen comes after the game is loaded. According to my weird experience, these are the results.
After launching the Game:
Core 1: 65-95%
Core 2: 70-99%
Core 3: 60-98%
Core 4: 50-96%
GPU: 60-99%
At white loading room
Core 1: 10-46%
Core 2: 15-65%
Core 3: 12-69%
Core 4: 9-40%
GPU: 38-99%
At black screen
Core 1: 5-12%
Core 2: 6-20%
Core 3: 0-22%
Core 4: 0-5%
GPU: 0-20%
Please help a fellow gamer out of this weird situation. Please reply
I've been playing Assassin's creed since Altair ibn-La Ahad was the center of attention (i'm on a horse!!! errr I mean boat??? no that was black flag...). Anywho... I've played nearly everything in the franchise and this game is just a hardware heavy mess that can be severely affected buy ingame settings and Nvidia control panel settings.
I would start playing around with settings and see if you can find a happy medium. I personally would use FXAA or TXAA on single sample (no x2 suff) and gernally try to set the game to a "normal" graphics setting.
For me Brotherhood was the worse with unsolvable microstuttering whenever I moved the mouse. Rogue so far seems to actually be better optimized than Black Flag, better graphics (well, about the same) but uses less GPU. Unity sucks.
Assassin's creed 3 was well optimized IMO, played on near ultra with my 750Ti on 1440p.
The_Tester : I have played all Assassin's Creed games (which includes Assassin's Creed 1,2,Brotherhood,Revelations,3,Liberation,4,Rogue and Unity) in ultra at 1366x768 except Unity which I ran at low-med settings at the same resolution. These ran great on my system. I finished Brotherhood 3 TIMES. Currently ,I am struggling to play Syndicate at lowest settings at 1280x720. If you would see my post of Jan 2 2016 ,you would notice the game starts fine at 40-50 frame rates and later hangs up. Now I am facing a great problem. The games is not loading in Sequence 3 . It gets stuck in the white loading room at 1 frame rate per second. The game hangs up and I have to force restart my laptop. Sequence 1 and 2 ran fine by the way. Does this happen to you and does the latest patch help ?
turkey3_scratch : I dont know about your mouse problem with Brotherhood as I played it with my Xbox 360 Controller. If you own Syndicate ,then please help out a fellow gamer.
turkey3_scratch : My card has vram of 4gb. Unity ran like a charm for me. I have heard that Syndicate uses 2GB minimum for pc's by the way.
Facing a real weird problem now. Syndicates not loading. Stuck at white loading room.
Found a solution to the not loading problem. Just switched the resolution to 1024x768 and the game loaded but game is lagging so much that it is unbearable.
HELP
turkey3_scratch : Ubisoft developed Syndicate so no wonder it will run great on Nvidia compared to AMD.
I wanted to see how many frame rates per second I was getting in Unity. To my surprise, it lagged horribly. I finished Unity 4-5 months ago and at that time it worked great. No lags. I don't remember the frame rates though
I have done a number of things since then . Updated my nvidia drivers, installed a lot of games, overclocked my graphic card and decreased page ram. I have got a weird problem though. Whenever i start my laptop, a weird CSript window opens for a few seconds and then closes itself. I have not updated Unity or Syndicate . I have not even downloaded the Dead Kings free dlc for Unity. Then how come the games which ran great before are lagging horribly now ? Has my laptop become a piece of junk ?
So ,any ideas what can i do to fix the problem. I think the Nvidia Optimus (never heard of it before) is messing my gaming experience. I suspect that the game starts to run on my intel graphic card instead of nvidia.
Any help is appreciated
