I recently built a new computer with the following specs (all components are new):
Intel Core i5-4570 @ 3.2 GHz
GeForce GTX 660 Superclocked 2 GB
PATRIOT x1 8 GB RAM
ASUS Z87-K Motherboard
WD 1 TB HDD
CORSAIR CX500M (500 W)
For the first 1 1/2 weeks of playing games on my new PC, it has been going well. However, I've been having an annoying problem that I cannot discern whether it's extreme or not. And the problem turns out to be the ASUS Anti Surge problem. I would play a game for 30 minutes, and my PC would automatically shut down on its own and start back up, leading me to the ASUS Anti Surge screen. I've experienced this problem over 5 times until I finally realized that I desperately need to seek help.
One unusual occurrence of the ASUS Anti Surge screen was this: http://i.imgur.com/35xu8OK.jpg
For some reason, the ASUS Anti Surge screen was not properly centered on the monitor, and a part of it was cut off on the left. This was the first time that happened.
Another thing to note is the Voltage. I'm not sure if 1.744 V is high for the processor, but here's a screenshot of the monitoring info using ASUS AI SUITE III: http://i.imgur.com/4FlA5bR.png
I've definitely tried searching through Google for some help on this ASUS Anti Surge problem, but I haven't been able to find any answer that would help out a bit.
Also note that I'm VERY new to these whole in-depth problems with computers, so it would be nice if you guys could guide me through this daunting process of finding the solution.
Please help me solve this issue as soon as possible. I would appreciate any help or response. Thanks. Let me know if any further info is needed.
PATRIOT x1 8 GB RAM
WD 1 TB HDD
