Question ASUS B150I-Pro Gaming/WiFi/Aura not booting anymore
Jan 3, 2020
Hi!
My setup:
  • MB S1151 ASUS B150I-Pro Gaming/WiFi/Aura Mini-ITX retail
  • CORE I7-7700K 4.20GHZ
  • SilvStone SST-AR06
  • Netzteil CORSAIR 600W SF600M Modular (SFX/80+Gold) retail
  • D416GB 3000-15 Vengeance LED wh K2 COR
  • 1TB MX300 SSD SATAIII
  • ASUS 8GB GTX1080 PCI-E Aktiv STRIX-Gaming
  • Silverstone SST-RVZ02B-W Raven HTPC Gehäuse - schwarz
I have this PC since 2017, went back to the shop and they flashed a new version on the MOBO to support the 7700K.
But since 1 month or so it starts having troubles while booting. Sometime it works somtimes not. Now its never booting.
CPU fan is spinning , GPU has power.
It starts of the the CPU check then RAM, but no 3-4 light on boot start.
Thought thats the power supply, so I got the same one and switched all cables and rewired everything. But with no success.
Tried resetting cmos but it did not change anything. Should I contact Asus or is there more I can try?
BR,
AS
Hi,
Thanks for your help!
Tried with onboard GPU only, but did not work.
I bought a speaker for the motherboard. It beeps 3 times then pauses then again 3 times. Then is over.
If RAM is completely gone it does the same 3 pause 3 but in a loop.
Sounds about RAM. I will by some other sticks today.
God save the 14 money back guarantee.
Will post my update later.
BR
