[SOLVED] Asus error code 96 (help)
Feb 8, 2021
I recently updated some software using the asus armory software. after restarting my computer I’ve notice that the computer kept crashing after a minute or so. I cmos the motherboard and reflashed the bios to version 1003
(While on bios after the reflashing process. I defaulted the setting and changed the primary display to pcie )
But now I’ve noticed that when I boot it show code 96 on the motherboard, and doesn’t post so I removed the graphics card and connected it to the on board graphics and it works and it doesn’t crash
but my issue now is that when I connect my graphics card to the motherboard the same code shows up and it doesn’t boot but when I connected it to the second pcie slot it works but not on the first.
would any one have any clue what to do?
I have a
asus Maximus hero xii,
i7 10700k,
2x8 3200 gskill
1080 evga
850w psu
custom loop.
hi, code 96 means pcie device cant get resources, which is odd with single gpu (could be bios bug)
try enable above 4G decoding option, that will give access for pcie devices to more resources
