[SOLVED] ASUS GeForce RTX 2060 Dual OC 12GB GDDR6 – system requirements
Daniel_Daniel
Commendable
Apr 13, 2022
31
5
1,535
Hi
I’m looking to upgrade my graphics card, and I can get this for about $640
https://www.ple.com.au/Products/650...xBiVIuq6S9Vl49xPjyMFsvA5F_EwgLEhoCtwIQAvD_BwE
I’ve never changed a graphics card before, and I wanted to check compatibility.
Case: CoolerMaster Silencio 452
CPU: Intel Core i5-8600 LGA1151CPU
Motherboard: Gigabyte GA-Z370 LGA1151-8
PSU: Corsiar 650W TX650M ATX (80 Plus Gold)
Monitor: Samsung M7 32” UHD
Does anyone see any issues here?
Thanks
Daniel
No issues, the GPU needs about 400w soo, compared with the other stuff, there is no bottleneck as of my knowledge.
PSU is enough, CPU supports it, and hopefully it will fit In the case.
Hope this helps
Hope this helps
Hope this helps
Thanks Monkey... the good call on the case dimensions
The maximum length is 386mm, and supplier lists it as 242 x 130x 53mm, so I think we are good!
