nofanneeded
Respectable
The cooler on the 3090 FE is really beefy. Its probably the 3090 cooler thats 150? Or did the 3080 FE cooler cost 150 as well?
There is no way that cooler costs $150 ...
Its not quieter with default fan curve, but the temps a lot cooler. So if you set the fan curve to get the temp similar to FE, it should be much more quiter.Yep, Nvidia's FE cooler is darn good this time around.
The AIBs do have their work cut out for them.
To me, the 3080 TUF Gaming isn't that impressive.
+I don't care for RGB anyway.
-It's not any quieter.
-It's ~50USD more, but Asus overcharges for most of their products anyway.
Plus, from what the different reviews have shown me, the FE model is slightly more efficient when it comes to dumping waste heat into cpu coolers - except front mounted cpu hybrid coolers.
Whodathunkit?
No one should be using the default fan curve, PERIOD. Custom curve, all day, every day.Its not quieter with default fan curve...
Ok?the temps a lot cooler.
Noise never was an issue for the likes of me.So if you set the fan curve to get the temp similar to FE, it should be much more quiter.
Unless you know more than NVidia engineers about thermal transfer, you might want tone down your remarks. They were working within a 2-slot package. A 2.7-slot design allows for about 30% more heatsink and ought to cool a hell of a lot better. Maybe you don't value the slot. Maybe others do. But crowing over the different results seems... umm... extremely uninformed.So... nVidia paid about $155 per card for the fancy-schmancy cooler on the FE models and ASUS just turned around and proved that it wasn't necessary.
I guess I went to the wrong area of the Asus site or something. LOL. But ... I'm super skeptical of the ROG Strix actually maintaining a 115MHz higher boost clock. I mean, the TUF I looked at was running at basically identical clocks to the 3080 FE (+10-15MHz is all), despite a 75MHz spec advantage. I've got an MSI card that's supposed to have an 1815MHz boost. I'll have to check what the average clocks are on that, but while I saw initial clocks break 2000MHz, I don't think it maintained that. And the Strix is supposedly 100MHz higher still? I mean, maybe it really is overclocking that well. Certainly I'll be looking to check it out.
That could be true but it's still plenty big.Well not exactly , the FE card is shorter and more compact.
I honestly don't know. My post wasn't altogether serious. I just thought that it was funny that nVidia went nutz with this fancy new cooler (which reportedly cost a lot) and ASUS just releases a rather conventional-looking tri-fan solution.The cooler on the 3090 FE is really beefy. Its probably the 3090 cooler thats 150? Or did the 3080 FE cooler cost 150 as well?
Yeah I was making a joke. As for what nVidia engineers know about heat transfer, I'm sure that it's a good deal but since nVidia out-sources their Founder's Edition cooling solutions to Cooler Master (as shown by Steven Burke in a factory tour), I don't think that it matters much.Unless you know more than NVidia engineers about thermal transfer, you might want tone down your remarks. They were working within a 2-slot package. A 2.7-slot design allows for about 30% more heatsink and ought to cool a hell of a lot better. Maybe you don't value the slot. Maybe others do. But crowing over the different results seems... umm... extremely uninformed.
Edit: sorry, didn't notice the "be like" locution. Guess you are operating at some other level.
My answer was only for that 1 point - -"It's not any quieter". You made a whole story out of it by spitting the sentence into 3? My goodness!No one should be using the default fan curve, PERIOD. Custom curve, all day, every day.
And no one's going to notice a 1dBA difference at max fan speeds either. It takes 3dBA for that.
Ok?
The FE isn't melting either; those are perfectly acceptable thermals.
If you believe that bit's worth 50USD+, then by all means, help yourself to one.
Before I replaced the cooler on my 1080Ti Gaming OC, I ran the fans at 100% whenever I loaded up a game anyway. It never saw over 65C
I did say in my last post, "TO ME, the card isn't impressive", along with why.
I wasn't telling everyone else that the card was terrible. If you like it, that's cool.
Sure did! It's a bad habit of mine. I get trigger happy with multi-quotes!My answer was only for that 1 point - -"It's not any quieter". You made a whole story out of it by spitting the sentence into 3? My goodness!
NVIDIA's cooler is actually what people need who run more than one card in a computer.That could be true but it's still plenty big.
Now, the RTX 3090 is a triple-slot card which I think is ridiculous because the last triple-slot card I can remember was the Radeon R9 390x2:
and THIS monster had FOUR 4-pin connectors and a TDP of (get ready for it)
580W!!! THIS MAKES THE RTX 3090 LOOK LIKE A LITTLE PUPPY IN COMPARISON!
Well, I don't know if you looked but I'm not exactly a newbie. You're explaining how GPU coolers work to me in elementary terms and it's kind of endearing because it makes me feel young again. I'm sure you encounter a lot of dumb noobs here so I'm not mad or anything because I encounter them too.NVIDIA's cooler is actually what people need who run more than one card in a computer.
It is 2 slot thickness. With motherboard spacing at 3 slots this gives you a full slot depth for air flow.
Plus it dumps part of its heat directly out of the back of the case. Without using loud blower type fans and keeping fairly quiet.
These large 3 fan models are great for single video card systems. But for dual/triple card systems that would be a nightmare trying to get all of their heat out of the case. Almost all of it would have to go up and out the top and back causing much higher CPU/VRM and memory temperatures.
Been there done that!! several times.
