Asus GT 640 Tech Help?
Quicksilver1661
hi i have the below graphics card Asus GT640-2gd3
https://www.amazon.com/dp/B0088TKS20/_encoding=UTF8?coliid=I25ATXG2GLG0QC&colid=8OU6AUWD7P4R
this card worked fine for basic computer taks & watching. but after i wanted to try a game
Spider-man Shattered Dimensions for 1st time gaming in couple of years, it crashed.
the connection still works 70% of the time. but has dots & lines..
is this fixable? please see error log from Event Viewer below..
current Specs
Win 8.1
Intel i5 cpu 3rd or 5th Gen -have to check
10gb RAM XMS brand
ASUS P8Z77-V LK motherboard
Regards
Driver Management has concluded the process to add Service BasicDisplay for Device Instance ID PCI\VEN_10DE&DEV_0FC1&SUBSYS_83F31043&REV_A1\4&BAB4994&0&0008 with the following status: 0.
Driver Management concluded the process to install driver display.inf_amd64_74c972e5eb125870\display.inf for Device Instance ID PCI\VEN_10DE&DEV_0FC1&SUBSYS_83F31043&REV_A1\4&BAB4994&0&0008 with the following status: 0x0
Driver Management has concluded the process to add Service nvlddmkm for Device Instance ID PCI\VEN_10DE&DEV_0FC1&SUBSYS_83F31043&REV_A1\4&BAB4994&0&0008 with the following status: 0.
Driver Management concluded the process to install driver nv_dispi.inf_amd64_cc2df69582aea972\nv_dispi.inf for Device Instance ID PCI\VEN_10DE&DEV_0FC1&SUBSYS_83F31043&REV_A1\4&BAB4994&0&0008 with the following status: 0x0.
Driver Management concluded the process to install driver nv_dispi.inf_amd64_9f7ce8f616e9bf22\nv_dispi.inf for Device Instance ID PCI\VEN_10DE&DEV_0FC1&SUBSYS_83F31043&REV_A1\4&BAB4994&0&0008 with the following status: 0x0.
First of all, that card is very weak by todays standards. Doesnt mean, it should not be able to play that game, but depends on how long you been using it.
You need to start by updating your drivers.
The reason I ask is even if game is torrented that probably didn’t burn it either?
Cuz recently Avengers game will be coming out & I’m wondering if I should get it on steam on my PC or console
Torrenting games is a good way to get malware/viruses and break other things along the way.
Tom's Hardware does not support any form of software piracy. None. Period.
Closing this (old) thread now.
