Hello ![Smile :) :)](/data/assets/smilies/smile.gif)
I dont know if this is the right part of the forum to ask, but I will try anyway.
I have a HTPC with the Asus M4A785T-M motherboard...connected to my samsung 63" plasma tv... and now I just bought a Radeon 7750 Graphics card.
Well, here is my problem
I use a HDMI cable from the internal graphics card to the tv.
When i put the radeon in my pc, the tv says check signal cable... when it is connected to the radeon HDMI port.
If I put the HDMI cable into the onboard card, the same thing happens.
If I take the radeon out of the pc, the onboard card works again.
Now I have tried all the different options in BIOS, cant remember the options now, since I am on another pc, but from what I understand from the manual, it has to do with what card "boots" first, internal, pci, pci-e and so on..
and the same thing happens, when the Radeon card is in the pci-e slot, I get no picture at all, not when I plug the HDMI cable in the Radeon or in the onboard.
I read somewhere that I should use IRQ in Bios for enabling my Radeon, but after 1 hour with failing and testing, I still do not see any options to change IRQ for anything in Bios...
How the H... do I get this Radeon card to work? It works in another pc, so the card is ok.. but I do not understand why it wont work in this pc... The MB had a pci-e 2.0 slot, and from what I have read, it should not be a problem to use a pci-e 3.0 card in that slot.
Heeelp heeelp!
regards
A Bester
Heeelp heeelp!
regards
A Bester
