Asus M4A78T-E Socket AM3 help no post
sepaa2003
23
Asus M4A78T-E Socket AM3/ AMD 790GX/ Hybrid CrossFireX/ HDMI/ A&V&GbE/ ATX Motherboard
Ok I have a corsair 450watt psu / AMD Phenom II X4 955 HDZ955FBGIBOX 3.2 GHz/6 MB L3/125W Processor /
4 gig of Patriot Memory Gaming Series 4 GB (2 x 2GB) 240-Pin DDR3 PC3-12800 1600MHz CAS 9-9-9-24 Enhanced Latency Dual Channel Kit PGS34G1600ELK/
a 250 gig sata hd drive western digital / radeon 5770 graphics card
following the asus manual I can not get any post beeps . Nothing on the monitor.
? do I need a heartere psu like a 650???
^Good. Seems as a problem mobo.
Do you check that the processor and cooler are correctly installed?
The ASUS support is very good, but maybe isn't too fast as all the mobos' manufacturers. Imagine the problems that they receive per day.
First thing to do is go through the troubleshooting guide. The sticky was made to help builders with boot problems. Follow the link in my signature to navigate to the troubleshooting guide.
Come back with your results and when you post again, tell us how many +12v rails your PSU has and what the amp rating is.
Hi newcomer and welcome to the Tom's hardware forum.
This are the requirement for your 5770.
ATI Radeon™ HD 5770 System Requirements
PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
450 Watt or greater power supply with one 75W 6-pin PCI Express® power connectors recommended (600 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode)
Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
Minimum 1GB of system memory
Installation software requires CD-ROM drive
DVD playback requires DVD drive
Blu-ray™ playback requires Blu-ray drive
For an ATI CrossFireX™ system, a second ATI Radeon™ HD 5770 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per graphics card (included) are required
The recommended PSU is for the entire system, so, you are in the limit. I would upgrade the PSU for a 550W. Antec 550W
they want to send me a new MOBO , Sould I get a different one???
psu corsair 650
thanks For all your help
ok bought the mob through amazon .com , recived a full refund with no problems.
so I purcahed the ASUS Crosshair III Formula 790FX/SB750 AM3 DDR3 160O.C. 2PCIE@X16 iROG Motherboard
the install was simple!!! The only problem is the pcie sound card I can not get any sound out .
help.
