ASUS M5A78L-M/USB3 Usb 3.0 Does it work
CaptainSirBacon
21
I was looking at reviews for the ASUS M5A78L-M/USB3 unfortunately I already bought it and I was wondering do the usb 3 work? People say they do not work and im afraid cause i only have 2 usb ports on my case which is a raidmax 402wb. luckily i bought a usb hub but do they work with usb 3.0
Mobo: http://m.newegg.com/Product/index?itemnumber=N82E16813131942&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566
Case:http://m.newegg.com/Product/index?itemnumber=11-156-296
The board has 4 rear USB 2 ports & 2 rear USB 3 ports.
As i7 baby says it only has internal USB 2 headers meaning you'll only be able link the black USB 2 port on top of the case to the board.
One of these cables
http://www.newegg.com/Product/Product.aspx?Item=9SIA2970X40954&FM=1
Will let you use both case USB ports (only st USB 2 speeds) if its important to you.
A USB 2 hub will work on USB 2 & 3 ports.
A USB 3 hub will also work on USB 2 & 3 ports
There are no real compatibility issues.
One of these cables
