I searched the forum for an answer to this issue but all the posts were related to new builds so I am starting a new thread.
I have been using this computer for 2 years in it's current setup. Nothing has changed. There was no storms and the whole house has a surge protector and the tower has one as well. I don't know what I could have done to cause this so I am assuming it is a hardware issue.
Yesterday I was just using my computer as usual and suddenly the screen went blank and said there was no signal. I looked inside the case and saw the LED below the CPU (labeled CPU LED) was glowing red. I tried to reboot but though my computer appeared to be turning on, it wouldn't send a signal to the monitor. I didn't want to mess with it at 1am so I went to bed.
Today I pulled my tower out, blew all the dust out of it and checked to make sure everything was seated properly. I hooked everything back up and the computer booted up. No red LED. After about 10 minutes, it happened again, red LED was on and monitor has no signal.
I am able to turn my computer back on. I set my fan speed to turbo. Checked the monitor and the CPU is not getting above 50 deg C. It is idling currently around 35C. I am waiting to see if it keeps happening.
Is this indicative of the CPU failing? Do CPUs start to fail gradually or do they just work or not work?
Computer Specs:
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900)
CPU: AMD Phenom II X4 945 Deneb 3.0GHz Socket AM3 95W Quad-Core Desktop Processor HDX945WFGMBOX
GPU: EVGA 012-P3-1570-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16
Windows 7 64bit.
I am currently checking to see if BIOS needs an update.
It just did it again. CPU temp was 42C before it happened and CPU fan was running at around 2800 RPM.
Computer Specs:
Windows 7 64bit.
