asus m5a97 r2.0 is not supporting android based os :( HELP please
Abhishek68
4
i have an asus m5a97 r2.0 mobo and it is not supporting and android based os i tried phioniex os and remix os ...both of them stuck at root@android x86....like thing..help
Thought about trying VM android apps like blustacks or Andy instead ??
Bluestacks 2 is very very good although some portions if it are paid for options nowadays.
Abhishek68
4
but dude this aint the problem i dont want to install them ....you know about remix and pheonix os ? both of them are android based...they both got stuck on root@androidx86 in my pc ...i tried every thing :( but nothing happened also they both booted fine in my friends pc and any else pc i tested.
McHenryB
Admirable
root@androidx86 sounds like a command prompt, so I'd guess there is a graphics problem with your PC. What do the system logs tell you?
McHenryB
Admirable
Actually, remix OS is known to have problems with AMD processors, so it may well be a m/b issue. I suspect the same may be true for other Android versions.
These OSs are just beta software; if you have problems with them you should give feedback in the appropriate place; that way you help others.
