Asus intros a snappier TN variant of its 27" FreeSync gaming monitor.
Asus MG278Q Is A 1440p FreeSync Monitor With A TN Panel : Read more
The scheduled forum maintenance has now been completed. If you spot any issues, please report them here in this thread. Thank you!
Ill never use a crap TN+Film panel when there are 144Hz VA/IPS blah blah blah blah blah blah blah
Ill never use a crap TN+Film panel when there are 144Hz VA/IPS (and those based on them) panels avalable with 4ms responce times available for not much more and youd be hard pressed noticing the differance between 4ms and 1ms (or anything less than 8ms g-g anyway) and the increased color accuracy and near-unlimited viewing angles are more than worth the tradeoff in a few ms of responce time. TN+film is too early 2000s and it about time for it to be phased out, havent owned a TN+film since 2004 and ill never go back. more marketing gimmiks.
All things considered we felt that the Acer XB270HU performed the best in these specific tests. The response times were slightly slower than the Asus ROG Swift PG278Q and BenQ XL2720Z, but the benefit of that was that there was no overshoot on the Acer, whereas the others showed some moderate levels.
which is absolutely true. You're equating "not as good" with "not good at all".IPS is great for still images, not quite as much for moving ones (i.e. games)
