Asus Motherboard Problem
Hansaj
I have asus M2N68 AM PLUS motherboard with AMD ATHLON 64 5600+ CPU.
At morning computer suddenly turned off . After 15 min When started it; it turned on for 2 sec and and then turned off.
I have checked it outside case with other psu but same thing occurs.
Also checked with minimal but not woking. Also tested with other RAM and integreated graphics not works.
I have checked my PSU with other pc it works.
As cpu is heat up quickly in my case cpu not heatiing a bit. So i think perhaps cpu problem.
And i checked all capacitors but not fired all of them.
Specs
Asus m2n68 am plus mobo
Amd athl9n 64 5400+ cpu
2 gb ddr2 ram
160 gb hdd
Windows 7 ultimate 64bit
Sorry for my english. But it is not my native language
Sounds like you need a new motherboard and Processor. Your computer is quite old. It is probably dying of old age. If I were you I'd replace it with an entry level Intel Processor. Preferably Pentium or Celeron.
