L Liquid-X Commendable Nov 30, 2016 186 0 1,680 Dec 3, 2016 #1 I have Maximus viii formula, and nzxt x62 kraken cooler, can i connect it to the Cpu header or to the water pump header
Solution alexoiu Dec 3, 2016 Yes, of course. You can use 2 separate PCIe cables to connect the power supply to the card.
L Liquid-X Commendable Nov 30, 2016 186 0 1,680 Dec 3, 2016 #3 alexoiu : To the CPU_Fan. alright, theres also a 4 pin cpu_opt, which i will connect my phanteks built in fan controller to, and on manuel it said don't connect Sata cable power if connected to opt_fan, so is the opt_fan same as cpu_opt? Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,818 250 126,990 Dec 3, 2016 #4 Yes, the same, but I'd rather connect the case fans to the motherboard, than to the case fan controller. Upvote 0 Downvote
L Liquid-X Commendable Nov 30, 2016 186 0 1,680 Dec 3, 2016 #5 alexoiu : Yes, the same, but I'd rather connect the case fans to the motherboard, than to the case fan controller. wouldn't it be the same thing? since my controller have a 4 pin, so it controls all the fans connected to the controller Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,818 250 126,990 Dec 3, 2016 #6 Yes, but I prefer avoiding additional connections. Upvote 0 Downvote
L Liquid-X Commendable Nov 30, 2016 186 0 1,680 Dec 3, 2016 #7 alexoiu : Yes, but I prefer avoiding additional connections. alright, also for my GPU, it is 8 pin and 6 pin, but my PSU did not come with 8pin to 6+2 and 6, can i use 2 8 pin to 6+2 cables Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,818 250 126,990 Dec 3, 2016 Solution #8 Yes, of course. You can use 2 separate PCIe cables to connect the power supply to the card. Upvote 0 Downvote Solution
L Liquid-X Commendable Nov 30, 2016 186 0 1,680 Dec 3, 2016 #9 alexoiu : Yes, of course. You can use 2 separate PCIe cables to connect the power supply to the card. ok, im installing hard drive right now, does it use the SATA cable that come with the PSU to power on? Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,818 250 126,990 Dec 3, 2016 #10 Yes, you connect the SATA power from the power supply and the SATA cable to the motherboard. Upvote 0 Downvote
