Asus motherboard Z10PE-D8 WS ( LED error bf ) urgent help needed
bobotheseal
Hi
I just build my PC suddenly my pc start but My monitor is black and LED on motherboard stuck at ( bF)
what I did so far :
1- Removed the battary form motherboard for a few seconds
2-Cleared the bios ram by moving the jumper for a few seconds
3-Updated the bios to the latest driver using USB Bios flashback
4-Remove video card and replaced it with another one ( same problem)
5-Changed the Card PCIe slot to another one ( same problem)
My configurations :
1-Dual Intel Xeon E5-2680 V3 2.5GHz
2-Asus Z10PE-D8 WS SSI EEB motherboard
3-2X Crucial 64GB (4 x 16GB) Registered DDR4-2133
4-Intel 750 Series 400GB PCI-E Solid State Drive
5-Zotac GeForce GTX 980 Ti 6GB
going to use this workstation for VFX simulation
This is the Q_CODE I got from motherboard using my USB stick I can't understand anything from it
Power ON
000F:01
0000:65
0008:01
0002:0B
0003:35
0006:01
0004:64
0006:FF
0019:FF
0011:01
0014:FF
00A1:02
00A3:02
00A7:02
00A9:01
00AA:05
00AB:01
00AC:04
00AD:01
00AF:FF
00B0:FF
00B1:27
00A1:01
00AF:--
RESET
000F:01
0000:62
0002:0A
0003:45
0006:03
0004:FF
0014:01
0019:FF
0013:01
0014:FF
00A1:01
00A3:02
00A7:03
00A9:02
00A7:02
00A8:01
00A9:01
00AA:02
00AE:01
00AF:FF
00BF:01
00B0:FF
00B1:41
00B4:56
00B2:FF
00FF:01
00B1:FF
00B3:0A
00B6:FF
00B7:FF
00BD:FF
00B7:01
00BD:FF
00B7:01
00BD:FF
00B7:01
00BD:FF
00B7:04
00BD:FF
00B7:01
00BD:FF
00B7:01
00BD:FF
00B7:09
00B8:01
00B7:04
00B9:FF
00BA:FF
00B7:03
00BF:--
Power OFF
DUMP Finish
Thank you for help!
Hi corndog1836
thank you for reply .. I found out that the motherboard is defective!
one of the two possessor slot is the reason for this message I'm going to send it back
Thanks
