Hello,
I am using the Asus P8Z77-M PRO board for almost 3years now, and it has it's problems for a long time now (about 2 years now), so i decided to finally register to this site and ask the community on what could be the problems with my board and if there is anything i can do to make it last longer.
So, my problems are, 2 out of 4 RAM slots are working and only 1 GPU PCI-E lane works out of 3. When I put ram in the 3rd or 4th slot, the computer does not POST, just the motherboard has a solid lit MemOK red LED, so I can only run my RAM in Single Channel which is a bummer. And the Main PCI-E slot does not work at all, the computer posts but just does not detect the graphics card at all, dosen't matter which card i use (GT220, HD2600XT, HD5450, 660TI, 970). The second slot detects the cards only while in bios before windows boot's, windows either blue screens or ignores the GPU and nothing shows up in Device manager other than the iGPU.
Would be great if you guys would give me any ideas on what i could do, but I suspect my board is about to kick the bucket.
PC Specs:
Mobo - P8Z77-M PRO Bios is the latest, updated last week
CPU - Intel Core i7-3770K 3.5GHZ XMP overclock to 4.2GHz
RAM - 4x2 8GB Corsair Vengance DDR3
GPU - Nvidia GTX970 4GB
PSU - OCZ Fatal1ty series 550W
OS - Windows 10 Home x64
Thanks.
PC Specs:
Thanks.
