Hello,
I'm trying to install the ASUS P8Z77-m into my old iMedia D2317 chassis, its my first try at motherboard installing and I ran into trouble connecting the system panel lead built into the case (for the power button etc.) to the motherboard.
The connector looks like this:
6 wires, white+black, red+yellow, green+blue
but the pins on the motherboard are positioned differently, (one thing I overlooked when researching it):
Apparently I need the wires to look like this:
I suppose I would need to separate the pairs of wires for it to work, theres a few things I need help with:
1. Which colour wire connects to which function? e.g. power, HDD Activity LED, Power LED (the case only has one power button, no reset).
2. Is it easy to rewire the connectors? Can you buy those separate plastic connector parts to put the wires into?
3. Would simply buying a new case be easier?
Any advice or other methods to solve this appreciated thanks.
