Question ASUS PRIME H610M-A D4 LED codes ?
mmcclaf
Commendable
Mar 24, 2020
29
Hi all,
I have an ASUS PRIME H610M-A D4 motherboard with the correct DRAM installed on it, but after everything is connected, I'm getting a fast blink for a couple of seconds, then a slow blink for a couple of seconds then a long slow blink. I've been trying to scour for the exact LED codes for this motherboard but have only come across https://www.asus.com/support/FAQ/1047023/ which doesn't address this motherboard.
Would anyone have any ideas if the LED codes are the same, and if so, what should I be looking at? Like I said, brand new DRAM that is compatible with the board, brand new mobo, no chips, or anything, everything seated right but still having this issue.
Appreciate any helpful feedback!
Motherboard: Prime H610M-A D$
PS: Cooler Master MWE Bronze 500 Model: MPX-5001-ACAAB
RAM: 2x PATRIOT PSD48G240081 DDR4 8GB RAM
Processor: BX8071512100F - Intel Core i3-12100F
Hard Drive: 2TB, brand new, brand doesn't matter, nor an OS installed yet.
GPU: Only using the VGA on-board video
All hooked up, tried variations of one stick of RAM, both sticks of RAM, hard drive connected, hard drive disconnected, but same pattern of lights.
motherboard don't have onboard for decade
* Graphics specifications may vary between CPU types. Please refer to www.intel.com for any updates.
Reactions: mmcclaf
So I just tried throwing in a Nvidia GeForce 9800GT, didn't work, but I threw in a GeForce 8800 Ultra and it came on, and said the VGA was not supported by the UEFI driver. At least it's progress!
Thanks rgd1101!
Reactions: rgd1101
