Let's start of by saying that ASUS's before purchase sucks.
I tried to get an answer in ASUS , but i was not able to get a straight answer , even from one of the admins.
If you have the Asus Rampage IV Extreme, you might be able to help then..
Any way, lets start.
Soon i might be able to purchase the ASUS Rampage IV Extreme.
And i am considering a 3way crossfirex or a 3way sli system.
I might use 3 of those two graphics card types.
Personally i want to go with the SAPPHIRE 7970 6GB.
1- SAPPHIRE TOXIC HD 7970 GHz Edition 6GB GDDR5 with dimensions of 10.83" x 4.53" x 2.04"
NewEgg Link |||| SAPPHIRE Official Link
2- Galaxy GeForce GTX 680 GC 4GB with dimensions of 10" x 4.33" x 1.57"
NewEgg Link |||| Galaxy Official Link
[strike]I want to know what is the proper configuration to run those 3 big cards.
Keeping in mind two things.
1- Air space between cards for ventilation.
2- Using both PICe x16 at (1) and (4).
I am thinking of using (1) and (4) and (6) with crossfireX (at least the main card will be well vented)
but i do not know if it is possible or not, due to card dimensions.
I do not know if this is impossible will it be possible with the Galaxy's GTX 680 4GB GC or not , and if it is possible
What will be better 3 SAPPHIRE's at x16 x8 x8 or 3 Galaxy's at x16 x16 x8 considering also the ventilation.
This is a problem , and i want to know your suggestions.[/strike]
The question is : how much is the distance between the (1) , (2) , (3) , (4) , (6) PCI slots in mm or in inchs.
