Hey there,
I've just noticed that my middle fan is whispering when active. it's quite annoying since it is pretty audible at 1 - 60% fan speed, where above 60% it blends into overall other fans noise.
I made a video of the noise here.
Is it possible to use WD-40 Silicone or something else to make the whisper go away?
I know that Noctua fans hate lubricant, so I'd kill it if I used some WD-40 Silicone [a lubricant, not degreaser like standard WD-40] on Noctua SSO2 bearing, but could I use it for this fan?
Any opinion is appreciated, since pushing my card to RMA would equal to a GPU suicide at this time [massive RTX 4090 shortage].
I don't need my cash back, I want an functional graphics card, they'd give me a cash back instead 😕
Thank You for any insight or feedback guys!
With best regards
uplink
P.S.: Before applying a lubricant, I'd remove the fan, it's attached there on a few screwes, they can be seen on the video too, I just hope tha there's at least some leeway with the cable. I plan to create a paper towel basin for the fan and than use the oil/lubricant by directly applying it to the motor/rotor if applicable.
With best regards
uplink
