Asus RT-AC68U - UPnP problem - Asuswrt-Merlin firmware
kemperkipie
703
I've got an Asus RT-AC68U in my network. Now is the problem that I've connected it directly to my provider, which basicly works.
Problem is, my provider put me in quarantine-network because I had UPnP enabled.. Now I've disabled it, because I simply don't use it at all. [back at normal network after contact with provider] Only my router doesn't seem to like it. It keeps giving me disconnects and errors.
Here's a piece of the log:
Feb 18 21:42:37 pppd[668]: No response to 10 echo-requests
Feb 18 21:42:37 pppd[668]: Serial link appears to be disconnected.
Feb 18 21:42:37 pppd[668]: Connect time 6.1 minutes.
Feb 18 21:42:37 pppd[668]: Sent 1344348 bytes, received 4066506 bytes.
Feb 18 21:42:37 dnsmasq[862]: read /etc/hosts - 5 addresses
Feb 18 21:42:37 dnsmasq[862]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:42:37 dnsmasq-dhcp[862]: read /etc/ethers - 1 addresses
Feb 18 21:42:37 dnsmasq[862]: using nameserver [IP]#53 for domain local
Feb 18 21:42:39 WAN Connection: Fail to connect with some issues.
Feb 18 21:42:39 stop_nat_rules: apply the redirect_rules!
Feb 18 21:42:39 dnsmasq[862]: exiting on receipt of SIGTERM
Feb 18 21:42:40 dnsmasq[1058]: started, version 2.73test6 cachesize 1500
Feb 18 21:42:40 dnsmasq[1058]: warning: interface ppp1* does not currently exist
Feb 18 21:42:40 dnsmasq[1058]: asynchronous logging enabled, queue limit is 5 messages
Feb 18 21:42:40 dnsmasq-dhcp[1058]: DHCP, IP range [IP] -- [IP] , lease time 1d
Feb 18 21:42:40 dnsmasq[1058]: read /etc/hosts - 5 addresses
Feb 18 21:42:40 dnsmasq[1058]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:42:40 dnsmasq-dhcp[1058]: read /etc/ethers - 1 addresses
Feb 18 21:42:40 dnsmasq[1058]: using nameserver [IP]#53 for domain local
Feb 18 21:42:43 pppd[668]: Connection terminated.
Feb 18 21:42:43 pppd[668]: Sent PADT
Feb 18 21:42:43 pppd[668]: Modem hangup
Feb 18 21:42:53 pppd[668]: PPP session is 482 (0x1e2)
Feb 18 21:42:53 pppd[668]: Connected to [MAC] via interface eth0
Feb 18 21:42:53 pppd[668]: Using interface ppp0
Feb 18 21:42:53 pppd[668]: Connect: ppp0 <--> eth0
Feb 18 21:42:53 pppd[668]: Remote message: Authentication success,Welcome!
Feb 18 21:42:53 pppd[668]: PAP authentication succeeded
Feb 18 21:42:53 pppd[668]: peer from calling number [MAC] authorized
Feb 18 21:42:53 pppd[668]: local IP address [hidden]
Feb 18 21:42:53 pppd[668]: remote IP address [hidden]
Feb 18 21:42:53 pppd[668]: primary DNS address [IP]
Feb 18 21:42:53 pppd[668]: secondary DNS address [IP]
Feb 18 21:42:53 rc_service: ip-up 1071:notify_rc start_firewall
Feb 18 21:42:53 dnsmasq[1058]: read /etc/hosts - 5 addresses
Feb 18 21:42:53 dnsmasq[1058]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:42:53 dnsmasq-dhcp[1058]: read /etc/ethers - 1 addresses
Feb 18 21:42:53 dnsmasq[1058]: using nameserver [IP]#53 for domain local
Feb 18 21:42:54 wan: finish adding multi routes
Feb 18 21:42:54 rc_service: ip-up 1071:notify_rc stop_upnp
Feb 18 21:42:54 rc_service: waitting "start_firewall" via ip-up ...
Feb 18 21:42:54 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Feb 18 21:42:54 dnsmasq[1058]: exiting on receipt of SIGTERM
Feb 18 21:42:54 dnsmasq[1093]: started, version 2.73test6 cachesize 1500
Feb 18 21:42:54 dnsmasq[1093]: warning: interface ppp1* does not currently exist
Feb 18 21:42:54 dnsmasq[1093]: asynchronous logging enabled, queue limit is 5 messages
Feb 18 21:42:54 dnsmasq-dhcp[1093]: DHCP, IP range [IP]-- [IP], lease time 1d
Feb 18 21:42:54 dnsmasq[1093]: read /etc/hosts - 5 addresses
Feb 18 21:42:54 dnsmasq[1093]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:42:54 dnsmasq-dhcp[1093]: read /etc/ethers - 1 addresses
Feb 18 21:42:54 dnsmasq[1093]: using nameserver [IP]#53 for domain local
Feb 18 21:42:55 WAN Connection: WAN was restored.
Feb 18 21:42:55 rc_service: ip-up 1071:notify_rc start_upnp
Feb 18 21:42:55 rc_service: waitting "stop_upnp" via ip-up ...
Feb 18 21:42:58 rc_service: ip-up 1071:notify_rc start_firewall
Feb 18 21:42:58 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Feb 18 21:42:58 dnsmasq[1093]: exiting on receipt of SIGTERM
Feb 18 21:42:58 dnsmasq[1149]: started, version 2.73test6 cachesize 1500
Feb 18 21:42:58 dnsmasq[1149]: warning: interface ppp1* does not currently exist
Feb 18 21:42:58 dnsmasq[1149]: asynchronous logging enabled, queue limit is 5 messages
Feb 18 21:42:58 dnsmasq-dhcp[1149]: DHCP, IP range [IP]-- [IP], lease time 1d
Feb 18 21:42:58 dnsmasq[1149]: read /etc/hosts - 5 addresses
Feb 18 21:42:58 dnsmasq[1149]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:42:58 dnsmasq-dhcp[1149]: read /etc/ethers - 1 addresses
Feb 18 21:42:58 dnsmasq[1149]: using nameserver [IP]#53 for domain local
Feb 18 21:44:15 rc_service: httpd 606:notify_rc restart_firewall
Feb 18 21:44:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Feb 18 21:44:15 dnsmasq[1149]: exiting on receipt of SIGTERM
Feb 18 21:44:15 dnsmasq[1185]: started, version 2.73test6 cachesize 1500
Feb 18 21:44:15 dnsmasq[1185]: warning: interface ppp1* does not currently exist
Feb 18 21:44:15 dnsmasq[1185]: asynchronous logging enabled, queue limit is 5 messages
Feb 18 21:44:15 dnsmasq-dhcp[1185]: DHCP, IP range [IP]-- [IP], lease time 1d
Feb 18 21:44:15 dnsmasq[1185]: read /etc/hosts - 5 addresses
Feb 18 21:44:15 dnsmasq[1185]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:44:15 dnsmasq-dhcp[1185]: read /etc/ethers - 1 addresses
Feb 18 21:44:15 dnsmasq[1185]: using nameserver [IP]#53 for domain local
Why this:
I don't want UPnP, and think this is causing the problem!!
I've disabled it in my router, and even black-listed UDP port 1900 from 0.0.0.0 to 0.0.0.0
What else can I do?
