Today I got the new monitor an ASUS TUF Gaming VG27AQ1A all pixels ok, g - sync perfect (as I booted to windows got the message bout G sync detected), just a mild ips glow on the bottom right and all pixels are fine. So at the moment I'm quite happy, now I'm struggling about settings, I've used the TFT central ones about ASUS TUF Gaming VG27AQ because I can't find any specifici for my 1A, so shoud I stick to them or there's something to change? And brightness set to 0 looks just wrong btw.
Thank you
I'm also using overdrive 60 by default, should I change it? and About overclock? It's supposed to go up to 170 but I didn't touch it and I left it set on 144
Thank you
