Hi there!
My asus ve228h lcd monitor is not working from last few days. Actually, few weeks ago when i changed my home office settings and move everything to another room, the lcd started behaving very strange i. e, when at first i plugin the power it did not detect it all (mean no light in the power led) . I tried different power supply and switches but everything gone invain. Then I check another lcd and it work just fine and meanwhile when i plugin power again to asus monitor it just lighten up. I was happy that it's working fine so i ignored this issue at all.
After few days, when for some reason I unpluged my monitor and re connected the problem was there again. And I recall the trick i have done before, connect another lcd with the power supply and again connected to asus lcd. The method worked and I was back to my work.
But you know, good things does not last longer. Day before Yesterday, when i redo the process and follow my so called trick, IT Did Not Work 🙁
Now my lcd is not lightning up, no power signs in the led and I did every possible change i can but nothing works. Please kindly help me out with this issue and ignore my English.
Thanks
Thanks
