I have had this monitor since last October and noticed that at random intervals I would have this bizarre artifact/screen tearing thing happen to it. When I first setup the monitors I set the refresh rate to 165hz but when it happened the first time I found that my solution was to reduce it to 144hz. Now it is happening again and I have tried everything there is to try.
I have swapped the cables, swapped ports from my GPU, I have updated my drivers for both my GPU and integrated graphics, I have factory reset the monitor, I should also add that I have two of these and the other one doesn't have any issues.
The issue only arises when I move a window into a certain place on the screen, for instance, I am typing this forum on the problem monitor with no issues what so ever, I should add that I can also play games with this montior and experience no issues.
Here are some images of the issue:
Display at 144hz, when a window is moved into the region on screen: Image 1
Display at 144hz, when the same window is moved out of that region: Image 2
This is what happens when I set the monitor to 165hz: Image 3
All help is appreciated, thanks in advance!
