asus vg248qe 144hz - not decided witch cable
Jan 11, 2019
7
I am undecided of chosing the right cable for this monitor to get 144hz.I bought in the past a hdmi to dvi that its not working so I'm not sure what is better and if its working so please tell me if I should go for dvi to dvi dual link or dvi to display port.Thank you for your help!
- Source Sirtec - 500W
- Processor Intel Coffee Lake, Core i5 8400
- Video Card MSI GTX 1060 6gb
- Motherboard MSI B360M PRO-VD
its 6GT OCV1 but I don't think it has display port. Will dvi to dvi give me 144hz with this monitor?cause I also have a hdmi - displayport but it doesn't work..
https://www.newegg.com/Product/Product.aspx?Item=N82E16814137053&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Yes, it has DP 1.4
If you have DVI-D to DVI or DVI-D to DP or DP to DVI, those may work too. If not, just buy a DP-DP cable.
Alright!Thank you very much!
