Hi,
i bought a new Case(Define R6 Black). this one has a built-in fan controller (Nexus smart HUB) and i added a new custom watercooling System
my question is now where do I plug in all fans and the controller?
I have 3 fans for the radiator water cooling System which I would plug with a y-cable to CPU_FAN. I can control them in Fan Expert.
The pump on AIO_PUMP
now I have 3,4 pin fans which I would connect to the hub. where do I connect it?
and is it normal that I can't control the pump via the connection AIO-PUMP? in Fan expert 4 it shows a pump but the RPM FIX mode is deactivated? is there a solution for that?
and sorry for my bad English ^^
