Asus Z77 sound card - Volume too low
Revelations
Commendable
Jul 30, 2016
6
I tend to use my Sennheiser 598 headphones connected to a speaker bar that came with my Dell U2412M monitor. I've turned the sound all the way up, but the volume is insanely low. I tried plugging my headphones directly into the Fractal R4 to see if it was the speaker bar, but it didn't change the issue.
Should I go and buy a sound card? If so, could I get a recommendation. I didn't even think they made sounds cards anymore.
did u use other headphones yet? if other headphones does the same, make sure u plugged in the right way.
