So guys, here is the thing, I am building my new setup, with an Asus Sabertooth Mark S and i5-4690k.
I intalled everything and the firt time i booted there was no video signal and the CPU_led was red on the mobo.
I checked the cpu pins on the mobo and they are not bend. I tried running without the Vga and memories and the same thing happens.
For last I tried updating the bios with the usb, since I read that the DC was not reconizable from the factory bios. I tried flashing it a couple of times, but it still gives me the Cpu_led red and now I dont know if I killed the mobo by not doing it correctly or if the problem is something else.
Fyi the way i updated was: I downloaded the .cap file and renamed it according to the manual "Z97STS.CAP", plugged in the mobo flash usb, removed everything but the power cables and held the button for 3 secs. The button light blinked a couple of times and after it stopped i turned it off, re-installed everything and tested it.
Can someone share some thoughts of what might be happening?
