I'm working on a friend gaming build and its not that bad. The problem overall is not fully booting. It boots up for 1-2 sec and shut back down. I've tried every method I can think of from A+ to whatever I can find on google. Everything is practically brand new. The specs are
Case: CoolerMaster Stryker
Mobo: Asus Z97 Deluxe
CPU: I7 4770K
Memory: Patriots 16GB 2400Mhz (8gb*2)
PSU: EVGA SuperNova G2 1000w
GFX: Geforce 8800GT
http://s952.photobucket.com/user/itzdaviboi/media/IMG_00232.jpg.html for picture
I tested the PSU to make sure its not a defect with the paperclip method. It got continuous spin.
I looked for shorts, on the copper mounts where the motherboard sits on, looking for loose screws if there is any, and making sure no wires touching part where its not to be at.
I went down to one memory stick and jumper onto every slot. Then rotated to the other memory stick. Problem still persist.
Took out the CPU 12v cable from board, system ran continuous, but the led won't change past 00. Might be a bad CPU?
Took out the CPU, Board boots up, LED red on the CPU side.
Need a 2nd, 3rd, or 20th opinion on this. Want to make sure I'm right on the ball before moving on. Been working on this for 2 days so far.
CPU: I7 4770K
GFX: Geforce 8800GT
