Question Asus Z97I-PLUS powers on, spins CPU fan for a second and then stops, does not POST ?
Dec 15, 2020
4
Hi,
I've had my Z97I-PLUS custom build PC for about 3 years been working fine; last year it switched itself off and shows similar symptoms...Pressed Power button On, fan spins for a second and then stops, PC does not boot. So last year I removed the CPU cleaned up and applied new thermal paste and reset CPU - this worked so I just put it down to must have been over heating and thermal paste was wearing out.
Last week (a year later approx.) I went to access the PC and it was already powered off, tried to power on but got stuck in the same loop "Pressed Power button On, fan spins for a second and then stops, PC does not boot." So I decided to do what I did last year which was clean the CPU, thermal paste and then reset CPU with new paste - this time it did not work, PC would not boot and is stuck on "Pressed Power button On, fan spins for a second and then stops, PC does not boot."
SPEC:
MB: Z97I-PLUS
CPU: Intel i5 CPU
Memory: Corsair 6GB (single stick)
HDD: 1 TB Samsung SSD
Removed Ram alternated sockets made no difference still the same issue, any ideas anyone ?
Could be the PSU needs replacing, that never occurred to you even though it's related to your problem?
What make & model is it, and how old?
PSU seems to be working as I mentioned the CPU fans spins for a second and then stops, green light on motherboard is lit.
Make/Model: MB ASUS|Z97I-PLUS Z97 ITX R
Approx 3-5 years old.
System is built on mini-ATX using case ANTEC ISK1110
Attached images of PSU, I went out and an purchased another replacement power supply, still the same issue.
