Athlon XP 3000+ running at 1750mhz on a7v8x-mx
mozaik
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi everyone,
I just upgraded my processor from a duron 800 to an athlon XP 3000+ 333fsb.
My motherboard is an a7v8x-mx. I set the dsw switch for the right frequency,
and the bios says that the fsb is 166 but the processor shows up as "Athlon
XP 1750mhz" instead of "athlon XP 3000+" as it should. Asus probe states
that the fsb is 166 too.
I have already tried clearing the cmos, loading the optimal settings,
changing the ram frequency from 166 to 133. I also tried setting the dsw
switch to 100 and 133, but I just get an "athlon XP 1400mhz" or "athlon XP
1800+".
My bios is version 1006 (the latest stable release), the asus site and the
manual say it supports athlon xp 3000+ 333fsb.
The cpu temperature is 50°C and the motherboard 35°C. 400watt power supply.
I have searched the web and found other people with the same problem, but no
solution.
Can anyone help me? Should I try installing a beta bios ?
The computer seems to be running stable otherwise, except some weird error
with temp files when entering windows, but I don't think that's cpu related.
Any help on this would be really appreciated.
G
Guest
Guest
Mozaik wrote:
> Hi everyone,
> 333fsb. My motherboard is an a7v8x-mx. I set the dsw switch for the right
> frequency, and the bios says that the fsb is 166 but the processor shows
> up as "Athlon XP 1750mhz" instead of "athlon XP 3000+" as it should. Asus
> probe states that the fsb is 166 too.
> 1800+".
> supply. I have searched the web and found other people with the same
> problem, but no solution.
> related. Any help on this would be really appreciated.
The XP 3000+ with 166MHz FSB has a multiplier of 13. That gives 2.17GHz.
You have 1750MHz. If you assume that the multiplier is constant (it should
be locked) then your FSB is 134.6MHz. But everybody reports your FSB at
166MHz.
1750MHz/166MHz gives a mutliplier of bang on 10.5.
AMD XP processors with a 10.5 Multiplier are:
AMD Athlon XP 1600+ (Palamino) (unlikely to clock to 1750MHz)
AMD Athlon XP 3000+ (Barton) FSB of 200MHz.
Thats it. Just those two.
You have a 200MHz XP 3000+.
Ben
A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
Questions by email will likely be ignored, please use the newsgroups.
I'm not just a number. To many, I'm known as a String...
G
Guest
Guest
should
> 166MHz.
What you said makes alot of sense, but the place where I got the cpu only
sells one processor with that fsb, and it's a 3200+ wich costs about twice
as much as a 3000+/333mhz.
Also I remember looking at the processor before installing it and the
sticker mentioned it was a 3000+ 333fsb. If it's really a 400mhz, then it
must have been switched by mistake before reaching the store.
That would be quite funny actually. Especially for the guy who paid for a
400fsb and got a 333 hehe.
What should I do? The motherboard doesnt support overclocking, can I change
the multiplier or fsb in some other way?
Thanks for your help
G
Guest
Guest
>> should be locked) then your FSB is 134.6MHz. But everybody reports your
>> FSB at 166MHz.
What sticker? Is this an OEM or a Retail CPU?
What numbers are written on the CPU core?
> change the multiplier or fsb in some other way?
Multiplier is locked, FSB is maxxed out. Nothing you CAN do with it really
but run it where it is.
Take it back to the store requesting the CPU you paid for, or suffer the
speed loss of around 20%.
A Barton 2500+ is 166MHz * 11, so yours is running slower than that.
Basically you paid twice as much as you should have, given the speed you can
run your CPU at.
Ben
G
Guest
Guest
a
really
can
> run your CPU at.
This is an OEM cpu. The sticker was on the cpu surface. Not sure who put it
tho.
Is there any way I can make sure this is a 400fsb without removing the
heatsink?
I could get an a7v600-x with 400fsb for about 60 euros, and put the old
duron back on this motherboard.
dick
358
NewEgg sells a Barton core XP3000+ cpu that uses a 333 fsb with a 13x
multiplier (2.16GHz). $138US.
> a
> really
> can
>>run your CPU at.
> tho.
> heatsink?
rev
15
Mozaik,
I have an AMD 2800 with an A7V8X Deluxe and originally it showed like 1250
mHz instead of full speed.
I AM running Bios 1007 -- which is the latest for the mobo.
I have the CPU set to 166; CPU Freq Multiply set to Auto (which makes it
12.5); System Performance to Optimal; CPU Interface to Optimal; and Memory
Freq by SPD.
Been a long time, but seems like it was the bios update that got it working
for me.
Good luck!
Rev
"Mozaik" <joman@zibi.es> wrote in message
news:%mVKc.88281$G%.43863@tornado.fastwebnet.it...
> Hi everyone,
333fsb.
frequency,
"Athlon
> 1800+".
supply.
no
> solution.
related.
G
Guest
Guest
> it tho.
Thats odd.
> heatsink?
Trust me. If it's a barton with 10.5 multiplier (which it is) it's the
200MHz FSB XP 3000+
Or get the XP 3000+ with 166MHz FSB for about the same price you paid for
the 3000+ with 200MHz FSB.
Ben
G
Guest
Guest
> really but run it where it is.
Or it could indeed be unlocked. My XP3000+ /333 is unlocked from factory, as
a curiosity. I would certainly try to make sure that the multi is indeed 13
in BIOS.
G
Guest
Guest
But this bios doesnt show any multiplier.
There is just a DSW swtich on the mainboard wich can set the fsb to 100, 133
or 166.
Is there any software to see the multiplier?
as
13
> in BIOS.
G
Guest
Guest
> 133 or 166.
Yeah. Go to Start -> Run -> "calc"
:p
I've always used Aida to do that type of thing, it's called something else
now... Everest?
Ben
G
Guest
Guest
Rev wrote:
> Mozaik,
> Freq by SPD.
> working for me.
More likely it was setting the FSB properly.
It would have defaulted to 100 (*12.5)
But should be 166 * 12.5
Ben
G
Guest
Guest
On Wed, 21 Jul 2004 17:41:24 +0100, "Ben Pope" <spam@hotmail.com>
>now... Everest?
AIDA32 is no longer in development. The developer has joined Everest
(not the double glazing firm <g>).
Cheers,
Guy
"If you want to find out what is wrong
with democracy, spend five minutes with
the average voter." - Winston Churchill
