ATi 4850's Problem
69ers
125
Hey guys I got a BIG problem i don't know about u guys but my computer would show the BSOD well close to it . I'm running 2 HD 4850's and for some reason it shows me the "display driver isn't responding ." so i was wondering anything happen to u guys? i downloaded the hot fix and the same thing . Nothing changed... T_T
Try running just one GPU.
Check if both GPU's are working independently... And then fix both together in CF... try 'drive sweeper' and clean all ATi drivers... then re-install latest driver with Catalyst Control Centre.... Do you have enough PSU to power both cards?
do you have a good brand 1000w PSU? Even a bad one should be enough, but it might coz problems still.
other than that, clean all drivers, check if one works fine, then test both together.
