I cut my govee light strip to the length I wanted (yes, at the specified cut point), so I'm thinking about what to do with the other part. I want to use it inside my PC case, and my ASUS motherboard comes with a "Extension cable for Addressable LED". Can I connect the four contacts on the strip to this cable? I suppose the voltage of the header on the motherboard matters too, so which of the headers should I plug the cable into?
these are the options:
2 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
Thank you!
For reference, this is the strip I am talking about: https://www.amazon.com/Govee-Waterproof-Bedroom-Changing-Adhesive/dp/B07PCR7LPS/
Thank you!
