jaslion :
funnkyfeel :
Hey guys. Need some help. So basically, I have lost one of my modular cables for Pci-e (cft-650-14cs), now, can I use different cable, in different place to power GPU.
https://www.flickr.com/photos/157526240@N07/shares/K3C325.
Also, New GPU 1080ti 11GB
1. You need to use the correct cable as these ports are wired differently to provide different power
2. That psu can in NO WAY power a 1080ti anyways since it's a really low quality unit on the borderline of firehazard territory and since you lost the cable you might as well replace it with a QUALITY unit. What are your system specs so we can recommend you a proper unit?
Thats what I thought. K, I got i7 6700k ON z170a with 12Gb ram, 1Tb with 125ssd.
I am ON budget. What about these two?
Chieftec GPS750C powersmart series(cheaper)
Or Deepcool Gamerstorm DQ850W?
Cooler Master ATX 2.31 Vanguard 850W RS850-AFBAG1-EU (most expensive)
