ATX Power source, how to properly connect my components?
gshector88
Hello, this is my first time building a gaming PC and I've been watching tons of videos and reading tutorials about this topic, but I still have a few questions, specifically regarding the ATX power supply and how to connect all my components to it. Let me start by listing the components that are giving me a headache:
Power supply: EVGA BQ 650
GPU: Zotac ZT-P10700G-10M
Mobo: ROG Strix B350-F Gaming
CPU: AMD Ryzen 5 1600 Series
With that out of the way my questions are:
1- The motherboard has two ATX power connectors: the classic 24 pin connector (EATXPWR), and the 8 pin connector (EATX12V). The 24 pin is a no brainer, but I'm confused about the 8 pin connector; does this connector supplies energy to the AMD Ryzen alone? I'm confused because the notches don't match, BUT IT DOES CONNECT! What I mean is, that my power supply has two 4 pin connectors, each one have a small label that says CPU. Should I connect those in the EATX12V port? I'm not forcing anything, because the notched pins can easily connect into the square-shaped slots, but that makes me feel worried. Hopefully I'm being clear, but I'll post a picture later in case I need a better way to explain it.
2- This one is about the GPU. It came with a dual cable (one 8 pin end to two 6 pin end each one, I'm sorry if this cable has a name, but I'm ignorant and for some reason isn't even listed on my GPU box). I know those connectors are for my ATX PCI-E connectors, but should I connect both or just one?
That's it, pretty simple, right? I'm sorry if it's a noob question, but well, I think we all start knowing nothing. I hope you can help me guys, thanks in advance!
Yes, the two 4 pin CPU plugs go together for the 8 pin EATX12volt connection.
The adapter you mention is if you need it. The GTX 1070mini requires a 6 pin (I believe) PCI-e connection. If you only have an 8 pin on the PSU for PCI-e, then use the adapter, and use one end of the 6 pin connectors. If your PSU already has a 6 pin PCI-e connection, don't worry about the adapter.
Thank you both, dudio and Calvin7! So, let me get this straight, correct me if I'm wrong:
1- The 8 pin connector with the CPU label will go in the EATX12V, and as long as I'm not forcing it, the shape of the pins are meaningless.
2- My power supply comes with a 6 pin PCI-e connector and a 6+2 pin PCI-e connector; this means, since the port on my video card has an 8 pin connector, I'll directly connect the power supply's 6+2 pin PCI-e connector, no adapter needed.
I'll wait for your confirmation, cause truth be told, I'm a bit scared to power it up for the first time without really knowing if it's properly connected, because I'm such a newbie, I almost connected BOTH PCI-e connectors to my video card using the adapter! I think I almost ruined my video card for thinking "hey, if they included this adapter thing, it must be for something, right?"
yes 6+2 together into 8-pin on the gpu
no other cable needed
and yes this goes into the cpu header for power
data:image/jpeg;base64,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
