ATX Power Supply Questions
G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
I'm working on a project where I need the ATX power supply to be *on* at
all times.
Some motherboards support power on after power loss, but the board I'm
using does not support this feature.
I know you can turn an ATX power supply on by bridging pin 15 and ground (I
*think it's 15, definitely the green wire on most supplies). My question
is will I do any damage to the board doing this, and will it actually power
on the board?
> all times.
> on the board?
Pin #14, as shown in this photo...
http://www.burningissues.net/how_to/power/psu.htm
Peale <nospam.apeale69@hotmail.com> scrawled on the wall in
news:Xns94E565878A297nospamapeale69hotmai@130.81.64.196:
> Patrick <pberry26@yahoo.com> scrawled on the wall in
> news:3CCnc.541230$B81.10035992@twister.tampabay.rr.com:
> Yes, thank you. So will it work?
Anyone?
Bush and Kerry should NOT be in office!
Vote "None Of The Above" this coming election!
Make your vote count! Get the clowns out!
> Anyone?
As noted, shorting pin 14 of the PSU/MB connector to common *will*
start the PSU. Whether or not your MB will boot depends on the MB.
Some MBs have issues with PWR_GOOD timing when configured in this
manner. Try it and see.
On Wed, 12 May 2004 19:44:35 GMT, Peale <nospam.apeale69@hotmail.com>
>Anyone?
What do you mean, "will it work"?
That was kinda the whole point of the link and modification, no?
It's not particularly difficult to do, try it and see for yourself. The
main problem might be if there's a very brief power disturbance, long
enough to crash the system but short enough to not reset it, then the
system will be stuck, crashed, instead of rebooting. If you really need
always-on then consider using an UPS too, but of course NOT the UPS
software since it can't very well turn the machine off if the power supply
is rigged to stay on.
kony <spam@spam.com> scrawled on the wall in
news:ji65a0d8bahaudrm4r9ldtr10elruqg0v6@4ax.com:
>>Anyone?
I know that it will turn the PS on. My question was if it would do any
damage to the board if I did so.
> The main problem might be if there's a very brief power disturbance,
> long enough to crash the system but short enough to not reset it, then
> the system will be stuck, crashed, instead of rebooting. If you
> really need always-on then consider using an UPS too, but of course
> NOT the UPS software since it can't very well turn the machine off if
> the power supply is rigged to stay on.
It's going into an arcade cabinet running MAME. I *can* use an AT board
and power supply, but am very limited to how much speed I can use since
very few AT boards are made these days. Hence, I have to use an ATX
board.
The system will be running DOS. It's also wired to a central switch
which will turn on all the other things in the cabinet (marquee, arcade
monitor, coin door lights) so if the PS is wired so it is on all the
time, it won't matter.
The cabinet is done with the exception of this one last piece, and I just
want to get it right the first time, and not fry anything in the process.
On Thu, 13 May 2004 14:12:07 GMT, Peale <nospam.apeale69@hotmail.com>
No damage
>board.
Is MAME really needing that much performance? Lower performance setups
may also mean less heat, easier to cool, less airflow/dust/fan wear. I
suppose it's irrelevant though, since you already have the parts you want
to use.
It won't fry anything. You can test this youself though, by attaching a
load to the power supply (like a hard drive) then shorting the PS-On pin
you can confirm that the voltage levels are correct... that's all a power
supply is meant to do, supply those voltages within spec at varying
load... after you get the whole thing setup you ought to again measure
voltage levels to confirm that they're acceptable but it shouldn't be a
problem, just being extra cautious.
news:dh57a05c3om4gjpav0rl7fkli8g63aouao@4ax.com:
>>board and power supply, but am very limited to how much speed I can
>>use since very few AT boards are made these days. Hence, I have to
>>use an ATX board.
I'm guessing you've never used Mame before.
It depends on the game. Something like Pac-Man doesn't require much
effort. A game like Mortal Kombat does.
> setups may also mean less heat, easier to cool, less airflow/dust/fan
> wear. I suppose it's irrelevant though, since you already have the
> parts you want to use.
I'm building a classics cabinet as well that houses a 486. But that one
has an AT PS ;-)
>>arcade monitor, coin door lights) so if the PS is wired so it is on
>>all the time, it won't matter.
>>just want to get it right the first time, and not fry anything in the
>>process.
> a load to the power supply (like a hard drive) then shorting the PS-On
> pin you can confirm that the voltage levels are correct... that's all
> a power supply is meant to do, supply those voltages within spec at
> varying load... after you get the whole thing setup you ought to again
> measure voltage levels to confirm that they're acceptable but it
> shouldn't be a problem, just being extra cautious.
I know what they do, but since I only have just the one power supply, I
wanted to make sure I wasn't going to screw anything up.
Thanks for your replies!
Might be easier to build a little adapter. I have seen an extension
for the ATX 20 pin Plug like they use in taller Server Towers. Might
be possible to just take one and rewire it a bit.
There might be a power supply company that sells such a power supply
or a kit to modify it.
Might also be possible to rewrite the BIOS of a motherboard so it can
never tun off. Maybe a BIOS with no special power features.
>> all times.
>> on the board?
On Sun, 16 May 2004 22:48:27 -0500, Charles <LastBoyScout@whitehouse.gov>
If easiest is the goal, easiest would be buying a tap splice at the local
hardware store, using that to connect PS_On wire to ground near the PSU
casing end of the wiring harness.
http://www.trickcableandswitch.com/mall/flagtapsplice.asp
news:Xns94E4E49E29D13nospamapeale69hotmai@130.81.64.196:
Thanks to everyone that responded.
The solution turned out to not be bridging pin 14 and ground. That would
turn on the power supply, but not make everything run correctly.
I asked an electrical engineer friend, and he said to take a capacitor,
about 16v and 10uf or so, and put it on the power on pins on the
motherboard.
Since a capacitor is shorted when not charged, and becomes open when it
is, it is a perfect solution. Everything powers up instantaneously.
And because the cap is so small, it discharges very quickly, so you can
power cycle quickly, if you have to.
So what clown should we replace them with? By law we must have some clown
running things.
> running things.
Actually, we have to have a bunch of clowns. And we do.🙂
Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
http://mysite.verizon.net/res0exft/cpu.htm
Is the collective noun for a bunch of clown a clot? - A clot of clowns
sounds better than a bunch!
"Wes Newell" <w.newell@TAKEOUTverizon.net> wrote in message
news😛an.2004.06.27.07.57.42.908196@TAKEOUTverizon.net...
clown
> > running things.
On Sun, 27 Jun 2004 07:56:23 GMT, Wes Newell
>> running things.
What's important that OUR clowns do unto other clowns before they do
unto us.
Not exactly the golden rule is it ?
..... it's a beautiful thing 😉
