ATX standoffs misaligned, help?! (Picture inside)
Nitas
27
So I'm building a new system, and my Asus Z270H board doesn't fit with the ATX standoffs in my Fractal Design Define S case. What the heck is going on?? I'm kind of freaking out because this is one expensive build!
Take a look: http://imgur.com/a/ha8Xv
The board is a bit smaller than standard atx.
You have to use one additional plastic standoff to support your board.
No plastic standoffs came with the mobo or case :/ The mobo "fits" but the hole on the far middle right won't be used, and there is no hole in the case for it either.. I don't get it.
