K konstantinos.kotsias31 Commendable Aug 20, 2018 3 0 1,510 Aug 20, 2018 #1 So every time I boot up windows, I have to go to audio settings etc, to re-calibrate my audio balance because every time the left channel is 10% lower than the right! I don't know what's wrong! Can someone help?
Solution M M maxwellmelon Aug 20, 2018 right click on the sound symble on the task bar and select "sounds" in playback devices find your sound output and select property's go over to enhancements and try putting a check box by "disable all enhancements" go over to spacial sound and make sure it is off reboot pc is issue fixed?
M maxwellmelon Splendid Oct 2, 2013 2,511 0 24,010 Aug 20, 2018 Solution #2 right click on the sound symble on the task bar and select "sounds" in playback devices find your sound output and select property's go over to enhancements and try putting a check box by "disable all enhancements" go over to spacial sound and make sure it is off reboot pc is issue fixed? Upvote 0 Downvote Solution
