[SOLVED] Audio Balance Problem
mikelawrence202
15
I went to get on my pc today, and for some reason the audio is now only going through the right side. Everything I plug in is the same way, so it's not my headset. I have checked the audio balance and they are both 100. I can't see to figure out what the problem is, any help would be greatly appreciated !
Ok, some software balance aside, as in, some audio controlling software setting your balance all the way to the right side, it could be the 3.5mm port, try another one if possible, those ports has 2 connections inside it for the P2 3.5mm plug, one touches the tip wich handles the left channel and another that touches the plug a bit bellow, right under the insulator line, for the right channel, if one is not connecting our touching the channel properly, then no audio for that one, since stereo is standard nowadays it might be it.
