Question Audio disappear on "heavy" tasking
Feb 6, 2019
34
4
35
Hello everyone
Since my "old - new" R9 290, I noticed that my volume disappearing when gaming or watching movies. It occurs after 2-10 minutes, approximately, depends on how heavy the task is. I had a similar problem with the keyboard before and it was the energy management issue. Unfortunately I don't know how to fix that current problem with the audio, because I didn't found any option for energy management. Just to insure, it is probably the PSU right? and is there any fix without changing the PSU?
I7-4770k
Antec VP550 (delta old design)
R9 290
How old is the Antec PSU? Why did you refer to your GPU as an old-new R9 290 ? You might want to include the rest of your specs like so:
Motherboard:
Ram:
SSD/HDD:
Chassis:
OS:
Are you on the latest BIOS update for your motherboard? Include your audio equipment and if you're getting audio from the monitor, the make and model of your display.
Motherboard:
Ram:
SSD/HDD:
Chassis:
OS:
My bad, I meant that I bought an used R9, but was never used for mining and he is still in good performance. I had GTX 660 and I never had a problem with the audio , it started when I switched to the R9. My Antec is 7 years old
Motherboard Gigabyte GA-Z87X-UD5H (4th gen)
16 gb ram Corsair Vengeance
SSD 120 Kingdom + 1TB Black WD
Win 10 fully updated.
Audio is fully updated in device manager.
Updating** --> with monitor volume everything is fine. So I guess the problem is with the GPU indeed, because it stops the "power supplying" to the audio unit, am I right?
